windycityengineer
Message 1 of 6 (238 Views)
How Do I Freeze Point Number and Description?
238 Views, 5 Replies
12-04-2012 07:09 AM
I just received a drawing with a bunch of points in it. One of the layer is called V-ROAD-CNTR-PNTS. Unfortunately, the point number, description, and elevation are all in that same layer. How do I keep just the elevation turned on but turn off the point description and number? When I turn off or freeze the layer V-ROAD-CNTR-PTNS, all three disappear. I just need the elevation showing.
Attached is an image of my screen.
Toolspace > Prospector > Point Groups
You can find or make a point group containing these points.  Set the point group to display however you want.
Or if they are all already on the same style, you could just edit that style in Toolspace > Settings > Point > Label Styles
Jeff_M
Message 2 of 6 (233 Views)
Re: How Do I Freeze Point Number and Description?
12-04-2012 07:25 AM in reply to: windycityengineer
Change the PointLabelStyle to Elevation Only, either for all the points or for the PointGroup they belong to. May need to set the PointLabelSTyle Override in the point group if using that option.
windycityengineer
Message 3 of 6 (229 Views)
12-04-2012 07:52 AM in reply to: Jeff_M
I'm a novice at this. So please be patient.
So do I go to Toolspace on the left, pick the Settings Tab, and right click "Point"?
Or do I right click "Point Style"? And how do I do that for all the points?
Valued Contributor
bo.martin
Message 4 of 6 (213 Views)
12-04-2012 08:07 AM in reply to: windycityengineer
Point styles can be very confusing.
You will need to create a style that display the elevation only.
Or edit the stlye of the point selected and it will change all
the points with that style.
Good Luck!!
troma
Message 5 of 6 (210 Views)
12-04-2012 08:15 AM in reply to: windycityengineer
Credit where credit is due! Give kudos or accept as solution whenever you can.
windycityengineer
Message 6 of 6 (208 Views)
12-04-2012 08:18 AM in reply to: troma
That works. Thanks everybody for all your help.
