Civil 3D Forum
How do I customize Pipe Structure's Inner diameters?
4 REPLIES 4
2615 Views, 4 Replies
At the moment I'm trying to make a sewage pipe network, and I need something with a 7' diameter manhole.
I'm trying to use Concentric Cylindrical Structures, and I'm not able to make or use a part size with an 84 in. diameter.
Is it possible for me to enter in my own value for that property, instead of having to use the pull-down menu?
Thanks for your help,
P. George
4 REPLIES 4
> Thanks for your help, P. George
You have to customize parts with partbuilder.
good luck.
Jason Hickey
Civil 3D 2008, SP1
Dell Precision M70
2 GIG RAM, 256 MB nVidia Quadro FX Go1400
Intel Centrino 2 gHz Processor
www.civil3d.com
I had the same trouble but with a different part of the concentric cyndrical structure. I needed a floor thickness of zero so that my structures could look the way they always did in the profile view of our plans.
adding a new size in part builder is not difficult at all. You just have to find the right variable. The naming convention of the parts is only 3 letters and is a little confusing. floor thickness turned out to be Fth. makes sense once you figure out what it is. But I can tell you it wasn't my first choice 🙂
I suggest you open the part in partbuilder and have a look at the variables you can change and add. Shouldn't be too difficult to find the inner diameter.
clarkma5
I'm having a similar issue but I'm farther along. I have a 54" inside diameter eccentric cone sanitary sewer manhole with an associated style. However, the structure diameter was set to 48" because there was no 54" in the drop down list. I used the part builder to add 54" to the list and then went into my parts list and added that part size of 54" and associated it with my 54" style.
But I still don't have that 54" size available to me in the drop-down menu under structure properties! I cannot for the life of me figure out how to make this 54" size available to me in the drop down list even after creating it in the parts builder and adding it to my parts list. Any ideas?
I am using Civil3D 2014.
clarkma5
in reply to: clarkma5
Ah ha! I just got it. Instead of trying to edit the diameter in the structure properties, I just went to "swap part" under the right click menu for the structure and swapped it for the new part I had just created and added to the parts list!
Rail Community
