Civil 3D Forum
How do I add Gabbion Wall to my assembly in Civil 3D?
4 REPLIES 4
sb208918
483 Views, 4 Replies
I have been trying to add a gabbion wall to my assembly. But there is no standard subassembly for it. In the other  road design software that I use, there is option to enter the count of the gabbion steps and  wala!..the gabbion wall is added to the assembly with pre-defined parameters which ofcourse can be edited as per requirement. I am really surprised that Civil 3D doesnot have it. Is there a way around? Thankyou..
4 REPLIES 4
You can create your own using Subassembly Composer.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
I haven't had my hands deep on SAC yet, atleast not  to the point where I can enter no. of counts(eg.if n=9, 9 m gabbion wall is added to the assembly). Wouldn't doing so require a loop and to my knowledge, SAC doesn't have this feature added to it so far. So, how can it be done?
It does have copy and paste and you can copy how ever many steps you think you might require and have an if then statement for each n.
Civil Reminders
MikeEvansUK
in reply to: sb208918
Create a subassembly from polyline, Gabions only have set width & heights so just add each one to the subassembly accordingly and get the job done however I advise you to learn SAC for the next time as it can be really helpful.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Rail Community
