Valued Contributor
basman12
Message 1 of 4 (1,674 Views)
how can we reverse alignment direction ???
1674 Views, 3 Replies
03-27-2011 12:23 PM
Hello everybody
is there is any way to reverse the alignment direction
miked
Message 2 of 4 (1,671 Views)
Re: how can we reverse alignment direction ???
03-27-2011 01:18 PM in reply to: basman12
Select the alignment the ribbon will change and on the tab with alignment properties - Superelevation ect. hit the flyout and there you will find reverse alignment. Make sure you use the flyout not the drop down from alignment properties
NVIDIA Quadro 600
Civil3D 2012 64x
Jozi68
Message 3 of 4 (1,057 Views)
01-22-2013 11:11 PM in reply to: basman12
How does one "hit the flyout"?  I cannot find this command.  I'm using C3D 2012.
troma
Message 4 of 4 (1,046 Views)
01-23-2013 05:33 AM in reply to: Jozi68
The flyout is the part that "flies out" when you hit the little arrow on the bottom of the ribbon.
Credit where credit is due! Give kudos or accept as solution whenever you can.
