Civil 3D Forum
How can I get parcel center or mid coordinates
7 REPLIES 7
Message 1 of 8
dilsmails
976 Views, 7 Replies
7 REPLIES 7
Message 2 of 8
Neilw_05
in reply to: dilsmails
See the Map help file for how to create centroids for polygons.
Here is a link: http://docs.autodesk.com/MAP/2010/ENU/AutoCAD%20Map%203D%202010%20User%20Documentation/HTML%20Help/i...
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 3 of 8
Pointdump
D,
Just curious, but why would you want to?
The way you show looks pretty good. Create a point with a Northing/Easting point label. Bam. Done.
4-sided or circular parcels would be easy to find center, but deciding where center is on those two irregular parcels would be a challenge.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 4 of 8
Pointdump
in reply to: Neilw_05
Neil,
That's cool! I'd never heard of a Centroid before. Thanks for the link.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 8
I'm not in front of C3d at the moment but is the label marker at the centroid of the parcel? Im guessing you can pickup the marker coords in the label composer
Message 6 of 8
Jay_B
Horizontalcurveguy is correct, the Parcel labels are placed at the centroid of the Parcel.
There doesn't appear to be any information for the centroid available in Parcel Properties or the various Parcel label styles.
One work around, although not the most automated, is to create a "Note Label".
When  placing the Note Label, simply use the node osnap of any Parcel Label (which annotates the Centroid of the parcel).
I've attached a 2014 tutorial dwg with an example note label.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 7 of 8
BrianHailey
Just to put this out there, the Map tools do not locate the true centroid of the polygon as the point it creates is ALWAYS within the polygon (which makes sense for maps). The true centroid most definitely can lie outside of the polygon.
If you want the true centroid of a shape (mathematically defined, not map magic) you need to use the AutoCAD REGION command. Create a region from your polygon and then use the MASSPROP command on the region. This will give you the coordinates of the true centroid.
Also, in the testing I've done, the parcel label does not show up in the same location as the Map Centroid.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 8 of 8
HorizontalCurveGuy
in reply to: Jay_B
cool Jay
Can a block be added to the parcel label style and then the NE tagged to the block insert?
Rail Community
