Hello!
I have a very basic question about creating corridors. As you can see on the attachment, i created an assembly consisting of ditch and my own polyline subassembly and turned it into a corridor. The ditch part is drawn out correctly, but the other part (supposed to be a gravel road) has only sections in certain points. Does that have to do anything with adding codes and can it be explained here shortly?
Thank you!
Solved by mathewkol. Go to Solution.
Without the ability to examine your corridor properties I can't be sure but it appears to me your frequency settings are suspect. Looking at the screen capture it seems the sections are only being applied at vertical curves and vertical PI's. Check to see which geometry points are checked on in the frequency settings and try a shorter frequency interval.
There is no such thing as a continuous corridor, there are only sections at certain points. You have the option to increase the frequency as Neil tated. Now, what I don't see are lines connecting your road. Yes, you can use a polyline as an assembly but don't think you're done after you've converted it. You need to add Point, Link, and Shape codes to make it behave similar to other subassemblies.
You are not getting accurate information here in your quest to learn about the Corridor Object.
The Corridor Object is definitely a continuous longitudinal object with sub-elements that are used to create a contiuous 3D representation of a linear feature. The corridor sections are connected together by longitudinal Feature Lines (not Lines) that connect to Point Code locations on the subassemblies, and a 3D Chain created by an Alignment (Baseline) and Profile.
Polylines are not used to create Assemblies, but can be used to create subassemblies.
I would suggest practicing with the stock lane Subassemblies attached to an Assembly and watch closely how these elements work together. You can also Hatch and Render your Corridor through the Link Codes, and produce Material Volumes utlizing the Shape Codes..
I just wanted to expand a little bit on what Fred said.
A big part of my confusion when I was first trying to figure out corridors was the whole issue of points, links and codes.
Here's what I've learned about them in a nutshell. I originally wrote this for co-workers in my office to be able to use the sub-assembly composer to create a custom SA.
When you create a Point, Link or Shape (excluding the Auxiliary types), each of them have a “Code” property. This is the code that will appear within Civil 3D and allow you to create feature lines and shapes.
Don Ireland
Engineering Design Technician
