Civil 3D Forum
How can I draw underground ductbanks using civil 3D
18 REPLIES 18
Message 1 of 19
dilsmails1
8468 Views, 18 Replies
Hay all
I need an urgent help, how can I draw underground ductbanks using civil 3D. the attached pdf file shows an example of what I need.
Dileep
18 REPLIES 18
Message 2 of 19
odoshi
in reply to: dilsmails1
You may have a few options. Part Builder to use Civil Pipe Networks, Subassably Composer to use a Civil Corridor or use AutoCAD 3D solid sweeps.
Mike
Mike Caruso
Autodesk Certified Instructor 2014
AutoCAD/Civil 3D Autodesk Certified Professional 2014, 2015, 2018
www.whitemountaincad.com
Message 3 of 19
Joe-Bouza
Duct bank = pipe network.
you have options to draw rectangular, round and elliptical pipes.
Joe Bouza
Message 4 of 19
graf_p
I've been doing underground electrical duct bank deisigns like this for the past 2 years now. Pipe networks will not work for this application , if you need to show the duct banks with a vertical curve in the profile. Pipes don't bend (with a radius) vertically. I do use pipe networks for the manhole structures & corridor for the the duct banks. It get tricky when when a 6-way ductbank spits off with a 2-way and joins back with a 4-way. Sometimes it easier to just draw in the duct bank "by hand".
good luck,
Paul
Message 5 of 19
Joe-Bouza
in reply to: graf_p
Next option: use alignments ant profiles.
You can create a vertical profile of the DB with curve, etc. Extract the dynamic feature line from the alignment>> use a horizonal grading off the FL to make a dynami surface>> past that surface into a working surface>> raise or lower the DB height >> add that surface profile to the alignment and you will have a dyno duct bank
Joe Bouza
Message 6 of 19
vlsheehan
in reply to: Joe-Bouza
I do what Joe does but if I need an object for Navisworks for clash detection, I also extrude the ductback shape along the extracted vertical profile.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 7 of 19
Neilw_05
No need to make a surface. Just use a grading to create the vertical offset and add the grading FL to the profile.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 8 of 19
graf_p
in reply to: Neilw_05
I'm having hard time understanding this.. Can you give a little more detail? I would appreciates it very much.
Paul
Message 9 of 19
Joe-Bouza
I guess. I'll stick with the profiles
Joe Bouza
Message 10 of 19
Neilw_05
in reply to: graf_p
Here is an exerpt from this post:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/existing-utilities-water-gas-how-you-doin-it/...
We can utilize a grading and the ability to project a feature line to a profile to create a pipe in profile that remains dynamic to any profile.
Here is the concept:
1) Create alignments from the pipe runs
2) For pipes that follow existing terrain, sample the existing ground surface. For graded pipes, layout a design profile for the pipe run.
3) Create a featureline from the alignment and apply the EG or Design profile
4) Create a grading from the feature line with near vertical slope using the relative elevation option. Set the relative elevation to be the depth of cover to the top of the pipe. For power lines the relative elevation can be in the positive direction.
5) Create another grading from the previous to represent the diameter of the pipe, ie. relative elevation =minus .667 for an 8 in. pipe.
6) Project the feature lines from the 2 gradings to the profile to get dynamic profiles of the pipe. In cases where the diameter varies, apply appropriate relative offsets along the grading for each pipe size.
Here is a screen recording showing the dynamic relationship.
http://screencast.com/t/NzIxOGQzZDM
WIN 10 64 PRO
Message 11 of 19
graf_p
Thank you.. Can't wait to try this out!
Message 12 of 19
Very good Neil.
I would skip the EG portion and do the whole magilla with a layout profile for the inevitable need to modify it.
Message 13 of 19
graf_p
in reply to: HorizontalCurveGuy
I'm with you HCG.. I would have to use a layout profile with Neils procedure. There are too many underground utilitiies I have to weave over & under.
Paul
Message 14 of 19
dilsmails1
in reply to: graf_p
can you please add an exampole file in civil3D format
Dileep
Message 15 of 19
Joe-Bouza
mine uses a surface profile
Joe Bouza
Message 16 of 19
Neilw_05
What version do you have?
WIN 10 64 PRO
Message 17 of 19
Neilw_05
Frankly I don't think this technique is going to be of much help to you. It is better suited for long pipe runs that don't require a lot of detail. What you show in your example will require considerable detail so you are probably better off just drafting it all manually.
WIN 10 64 PRO
Message 18 of 19
dilsmails1
But it is not fulfilling my requirement, any way to shoe the pipes inside the ducts and clashes. (please see Detail-1,2,3) in the attached pdf) One more doubt about the giving elevations on the future line, I draw a future line and give the elevations in the vertexes, the I went to the elevation editor I wondered the elevations are no relations with the given elevations, I tried two three times but the result is same. What happening there? Any idea?
Dileep
Message 19 of 19
vlsheehan
I usually project the proposed grade from the profile onto the layout then explode that line. I'll then extrude the ductbank section along that line. I know it's not dynamic and I'll have to re-project the line if a change is made but it's not that time consuming. I usually export the ductbanks for Navisworks.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Rail Community
