Hi How can I control the display of corridor. Eg: I created contours using my corridor, after finishing my contour creation I don’t want to display the corridor sections. If there is an option to on offs the display of corridor. (same like like surfaces no display, border only etc..) Anybody can help me
if you don't want to see anything from the corridor then freeze the layer to which the corridor is assigned.
Otherwise you have to modify the CodeSet that is assigned to your Corridor and set the styles for Point/Link/Shape to something like "none".
Good luck, - alfred -
Although what Alfred is suggesting would work. If you are like me you hate recreatinging linework which your corridor will often generate. So best bet is to make link, point and shape codes that are no display in all view types. Next make a new code set out of the old one that keeps the feature line style, but clears out everything else and uses the no display styles.
