I got a .dwg file from my colleague but there is problem our northing and easting order is different, its like that X.200 Y:100 but what I want is X:100 Y:200.How can I change it without uploading points from the begening?
Solved by Pointdump. Go to Solution.
Gtan,
Without "uploading points from the beginning", I'm not sure. Here's what I'd do. Export points from your source drawing using a PENZD file format. Then import those points into a new drawing using a PNEZD file format. Or vice-versa.
Dave
Dave Stoll
Las Vegas, Nevada
I agree with @Pointdump . It sounds like a PENZD file was imported as a PNEZD file or vice-versa. Thus switching the Northing and Easting. There's nothing that can be done about that without reimporting using he correct format.
Allen
Allen Jessup
CAD Manager - Designer
