Civil 3D Forum
how calculate area for surface
5 REPLIES 5
29908 Views, 5 Replies
Hello everybody
how can i calculate the area for specific reigon of the surface?
can i know the volume for this region for a certain elevation ??
thanks
5 REPLIES 5
Joe-Bouza
Add a boundary and the statistics tab will give you the 2d and 3d area. for the volume create a plane surface at the desired elevation and compute the volume between.
Joe Bouza
nicolas.menu
In the ribbon : Analyze > Volumes > Bounded volumes
Nicolas Menu
Support Specialist, Civil 3D
Product Support
Autodesk, Inc.
bkanther
in reply to: nicolas.menu
This may solve for volumes but what about 3d surface area.
Are you telling me I have to add a boundary to a surface and go the surface area statistics every time i want a 3d surface area for a different polygon?
Brad
Its not often that I feel like I can contribute more on topics on here but for this one I think I might have an good technique to build on what the others said.
So basically I ran into a problem where Im taking Cut/Fill Volumes for a site but not the entire site was being paved, so if I lowered my entire finished surface by 6" or whatever.. Then in the areas where there wasnt paving I wasn't getting an accurate cut/fill results... so heres what I did...
* Calculate your cut/fill volumes from your Existing Surface vs. Final Surface -0.5'
* Calculate the area of your total site
* Calculate the area of the paved portions
* Multiply the difference by the thickness of your pavement and subtract that number from your cut.
Hope that helps!
ceethreedee.com
Wow old thread!
You might have saved a lot of time just using the volumes dashboard. Then using the bounded volumes option in there to restrict your calculation to a limited area.
Once you add the bounded areas they stay linked. So you can move them around or adjust the polygon and the volumes update!
The current bounded area you ahve selected get highlighted as well..
When your done -> right click -> copy to clipboard to quickly paste into excel...
Kapanther
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
Rail Community
