Civil 3D Forum
Horizontal Axis Labelling too Wide
9 REPLIES 9
Message 1 of 10
wings1080
570 Views, 9 Replies
Where is the setting to make these overly wide horizontal axis labelling fit the size of the actual graph instead of going so far beyond the limits please?
9 REPLIES 9
Message 2 of 10
Jeff_M
in reply to: wings1080
Your offsets are in a band. The SectionView properties tell the band to stagger labels when they overlap. Turn off the stagger and they will be centered on the vertical grid.
Jeff_M, also a frequent Swamper
Message 3 of 10
wings1080
in reply to: Jeff_M
thanks for answering, i selected station 750 and did no staggering and look how it turned out (below), what did i do wrong?
Message 4 of 10
Jeff_M
Nothing. Your text size is too big for your major tick spacing. Reduce the text size, or change your major tick spacing.
Message 5 of 10
wings1080
in reply to: Jeff_M
i'll try to figure out how to adjust the major tick spacing now because changing the font size did not seem to change anything, notice the font size in here is now .0025, it WAS .25, I changed it to .0025 and hit apply and the font size stayed the same, why?!
Message 6 of 10
Jeff_M
Because you are changing the SectionView properties. The labeling in your dwg is in the SectionView BAND, this is the style you need to edit the text size for.
Message 7 of 10
wings1080
in reply to: Jeff_M
ugh, a penny for a screen shot of that dialog box please???!
Message 8 of 10
Jeff_M
Look at the Bands tab of the SectionView properties, the one that has the Stagger setting. The far left of the line with the stagger will tell you which Band style is being used. You can click on it to edit directly from there.
Message 9 of 10
Jeff_M
in reply to: Jeff_M
Another method I have employed is to change the width factor of the Text Style used in the labels. Using a factor of 0.7-0.8 usually does the trick.
Message 10 of 10
wings1080
in reply to: Jeff_M
thanks for all your help with this, i had to punt and export to regular cad to edit due to a deadline and never got to try this but will refer to it in the future, appreciate it!
Rail Community
