Hi All,
Hopefully somebody can be of assistance, I have a highway and have created a sample line group to create my cross section and have displayed my cross sections without any issues. Currently my cross sections have three bands, Existing Level, Proposed Level and Offsets from CL. The existing levels are given at consistent intervals (1m intervals i think) which is fine, however the proposed levels are also shown at the same intervals. This means that while a lot of proposed information is shown across the cross section, the crucial information i.e, back of kerb, top of kerb, channel line and centreline is not always shown on the cross section.
Can anybody assist me in getting the Proposed Levels showing just the back of kerb, top of kerb CL etc. and getting the Offsets from CL to show the offsets for the Channel Line, top of kerb etc.
Hopefully i explained my scenario ok, any assistance would be appreciated.
Many thanks in advance for sharing your expertise!
I dont do much cross section deliverables but ZI'm guessing in the band style composer you can pick these point to lable (sort of like profile geometry is avalable) It might want to be its own band?
Your Name
Yep Pringles...
You can probably get what you want by using the surface selection “section 1 and 2”/configuring your styles and removing weeding.
First to help you understand the two section selections
Once you have this worked out you will want to make sure you have a style that is displaying elevations at “grade breaks and using the “section 2 elevations”
Then you should be laughing!
The section shown below uses a combination of Band and Code Sets. The band uses Section 1 as the EG and Section 2 is the Datum. The Code Set uses the Point and Link styles to label other components of the corridor. The offsets for EDGE BASE TAPER, ETW, CROWN & R.O.W. were all configurable, as well as the % slope of the pavement and the grade of the daylight.
