Hi all,
I have a verticval profile with a 5% grade, then a 50' vertical curve and then a -0.09% grade out. I have the label set to label the high point but the high point is only a couple of feet from the PVC. So the text is overlapping. How can I change the HP stationing so I can drag it to a new location. Like to the left a few feet. I would like to keep the same format of vertical text as in the attachent "VerticalProfiles-1. See attachment Vertical Profiles for my problem.
Thanks!
Put an offset on the High Point label component. See the Layout tab of the Label Style Composer.
Depending on the configuration of the existing line component, you might want to anchor its end point to the High Point label component.
