Civil 3D Forum
High point label in vertical profile
1 REPLY 1
trynders
313 Views, 1 Reply
Hi all,
I have a verticval profile with a 5% grade, then a 50' vertical curve and then a -0.09% grade out.  I have the label set to label the high point but the high point is only a couple of feet from the PVC.  So the text is overlapping.  How can I change the HP stationing so I can drag it to a new location.  Like to the left a few feet.  I would like to keep the same format of vertical text as in the attachent "VerticalProfiles-1.  See attachment Vertical Profiles for my problem.
Thanks!
1 REPLY 1
tcorey
in reply to: trynders
Put an offset on the High Point label component. See the Layout tab of the Label Style Composer.
Depending on the configuration of the existing line component, you might want to anchor its end point to the High Point label component.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
