i have an aerial inserted in Acad 2012, I can go to the insert tab and the pull down for hide frames, but it is still there when I plot.
Thanks.
Are you sure there isn't linework under the image frame? Did you check the command line to see if the button is working? Type IMAGEFRAME and see if it set to zero (no frames).
John Mayo
Thanks John,
Yes I tried that and it is set to 0, there is no line work under the image.
It is the line where two aerials come together, the hide frame command turns of the frame in model space, but shows up in paper space. I tried rebooting too. no luck.
You can also try IMAGEFRAME set to 2. Image Frames display but do not plot. Like Steve, I've seen my IMAGEFRAME setting not stick. Also check your FRAME setting as it overrides IMAGEFRAME, set it to 0, 2 or 3. ~ Mary
Yes I set Frames to 0-3 and no change. I thought it might be the view port so I deleted it and made another
with no change. I have another vp on that same page that is fine.
