AutoCAD Civil 3D General Discussion
*Expert Elite*
Joe-Bouza
Message 1 of 14 (214 Views)
Hide boundary
214 Views, 13 Replies
11-06-2013 09:20 AM
I have a user placing a hide boundary in a building foot print and a contour continues to go into the building. It only happens with contour smoothing on if it off it clips as expected, any ideas?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
*Expert Elite*
troma
Message 2 of 14 (189 Views)
Re: Hide boundary
11-06-2013 10:53 AM in reply to: Joe-Bouza
Do the TIN lines encroach too, or just the contours?
Credit where credit is due! Give kudos or accept as solution whenever you can.
Valued Mentor
IanMcClain
Message 3 of 14 (179 Views)
Re: Hide boundary
11-06-2013 11:19 AM in reply to: Joe-Bouza
Go to the Surface Properties>Definition tab and try putting the "add boundary" operation in question at the bottom of the list.
-Ian McClain
(running C3D 2012 sp4, Win7 64bit, 8GB)
*Expert Elite*
Joe-Bouza
Message 4 of 14 (176 Views)
Re: Hide boundary
11-06-2013 11:23 AM in reply to: troma
just the contour. a wee bulge
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
*Expert Elite*
Joe-Bouza
Message 5 of 14 (176 Views)
Re: Hide boundary
11-06-2013 11:23 AM in reply to: IanMcClain
Should have stated that is at the bottom
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
*Expert Elite*
Joe-Bouza
Message 6 of 14 (171 Views)
Re: Hide boundary
11-06-2013 11:26 AM in reply to: troma
Annoying.
Using a mask works but does not carry through the DS
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
*Expert Elite*
troma
Message 7 of 14 (164 Views)
Re: Hide boundary
11-06-2013 11:29 AM in reply to: Joe-Bouza
I think it is probably just a feature of the smoothing. Smoothing will also allow contours to cross each other. Of course that doesn't make sense either, but it is only thinking about smoothing the line (I think of it like a spline). It is not thinking about the surface definition anymore.
I mean, the surface definition gives key locations to the contour, and the smoothing algorithm figures out what to do between those locations, with total disregard to the original surface definition. That's my guess, anyway.
*Expert Elite*
Joe-Bouza
Message 8 of 14 (162 Views)
Re: Hide boundary
11-06-2013 11:30 AM in reply to: troma
I fugured as much
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
*Expert Elite*
troma
Message 9 of 14 (159 Views)
Re: Hide boundary
11-06-2013 11:32 AM in reply to: Joe-Bouza
If you think about it; with no smoothing, the 144 contour would keep going from one point to the next right along the boundary. You wouldn't see it because it would be right on the boundary, but it would be there. The smoothing just makes it more visible, but that segment exists regardless.
To get rid of it, lower those surface definition points by 0.0001. Now, the contour will end just before it reaches the edge of the surface, whether it is smoothed or not.
Valued Mentor
david.zavislan
Message 10 of 14 (111 Views)
Re: Hide boundary
11-07-2013 07:50 AM in reply to: Joe-Bouza
Try smoothing the surface, instead of the contours.  You will get better looking results, and the contours will stay within the boundary.
David Zavislan, P.E. | Wood Rodgers, Inc.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
