Civil 3D Forum
Hide boundary
13 REPLIES 13
Message 1 of 14
Joe-Bouza
605 Views, 13 Replies
Hide boundary
I have a user placing a hide boundary in a building foot print and a contour continues to go into the building. It only happens with contour smoothing on if it off it clips as expected, any ideas?
Joe Bouza
13 REPLIES 13
Message 2 of 14
troma
in reply to: Joe-Bouza
Do the TIN lines encroach too, or just the contours?
Mark Green
Working on Civil 3D in Canada
Message 3 of 14
IanMcClain
Go to the Surface Properties>Definition tab and try putting the "add boundary" operation in question at the bottom of the list.
Ian McClain
Message 4 of 14
Joe-Bouza
in reply to: troma
just the contour. a wee bulge
Joe Bouza
Message 5 of 14
Joe-Bouza
in reply to: IanMcClain
Should have stated that is at the bottom
Joe Bouza
Message 6 of 14
Joe-Bouza
in reply to: troma
Annoying.
Using a mask works but does not carry through the DS
Joe Bouza
Message 7 of 14
troma
I think it is probably just a feature of the smoothing. Smoothing will also allow contours to cross each other. Of course that doesn't make sense either, but it is only thinking about smoothing the line (I think of it like a spline). It is not thinking about the surface definition anymore.
I mean, the surface definition gives key locations to the contour, and the smoothing algorithm figures out what to do between those locations, with total disregard to the original surface definition. That's my guess, anyway.
Mark Green
Message 8 of 14
Joe-Bouza
in reply to: troma
I fugured as much
Joe Bouza
Message 9 of 14
troma
If you think about it; with no smoothing, the 144 contour would keep going from one point to the next right along the boundary. You wouldn't see it because it would be right on the boundary, but it would be there. The smoothing just makes it more visible, but that segment exists regardless.
To get rid of it, lower those surface definition points by 0.0001. Now, the contour will end just before it reaches the edge of the surface, whether it is smoothed or not.
Mark Green
Message 10 of 14
david.zavislan
Try smoothing the surface, instead of the contours.  You will get better looking results, and the contours will stay within the boundary.
David Zavislan, P.E. | Wood Rodgers, Inc.
Message 11 of 14
Joe-Bouza
in reply to: david.zavislan
I have done that but the results can be debatable
Joe Bouza
Message 12 of 14
tcorey
It looks like you have your Smoothing Type set to Spline Curve instead of Add Vertices
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 13 of 14
Joe-Bouza
in reply to: tcorey
Yes it does look that wat but it is set to add verts
Joe Bouza
Message 14 of 14
AllenJessup
I'd probably just cover them with a wipeout and be done with it.
Allen
Allen Jessup
CAD Manager - Designer
Rail Community
