I have a user placing a hide boundary in a building foot print and a contour continues to go into the building. It only happens with contour smoothing on if it off it clips as expected, any ideas?
Go to the Surface Properties>Definition tab and try putting the "add boundary" operation in question at the bottom of the list.
Annoying.
Using a mask works but does not carry through the DS
Mark Green
Working on Civil 3D in Canada
Mark Green
Try smoothing the surface, instead of the contours. You will get better looking results, and the contours will stay within the boundary.
It looks like you have your Smoothing Type set to Spline Curve instead of Add Vertices
I'd probably just cover them with a wipeout and be done with it.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
