Has anyone dealt with imaginary squares that don't show up until printing? I have some that show up everytime I print the sheets out. They are not visible until printing to plotter or making a .pdf. See attached example with red callout boxes. Thank you for any help anyone can provide.
Solved by AllenJessup. Go to Solution.
That was covered recently. See: http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Gray-boxes-appearing-on-plotted-drawings/td-p...
Your image is good enough that if you zoom in you can see that it's the Navbar.
Allen
Allen Jessup
CAD Manager - Designer
