I've just notice that I can add HGL and Flowrate label to my pipe Profile View but I have no idea how to add them.
Currently it label "0" for both of these fields.
Do I have to import these informations or write an expression to be able to label these fields?
Please help.
Thank you in advance
mmf
The flow rate and HGL are attached to the pipes.
To see them, select a pipe, right click and select pipe properties.
If you scroll down on the second tab, you see "Hydraulic Properties".
Under this is the HGL and flow rate values.
You can manually change them or import them (with a pipe network).
