Civil 3D Forum
Help files reference Object Name - what is that?
8 REPLIES 8
Message 1 of 9
1152 Views, 8 Replies
Hi, I got an easy one for you.  I don't understand what CAD is directing me to do.
I wanted to renumber some label tags.  The instructions in Help make reference to Ribbon click <Object Name> tab, labels and tables panel, renumber tags.  Of course I don't have a <Object Name> tab.  That would be too easy.  I could use the menu <Object Name>, add tables, renumber tags, but I also don't have a menu called <Object Name>.
This comes up over an over in help files.  I can't perform the commands because they don't seem to exist in my ribbon or menu.
What the heck is <Object Name>?  Where do I get access to it?  Where are all of the tabs and menus associated with it?
When I don't see it on the screen, I don't know how to click it.  The instruction is to "Click <Object name> tab > Labels & Tables panel > Renumber Tags. "  What would you click?
8 REPLIES 8
Message 2 of 9
tcorey
If you are dealing with tags along Alignment or Parcel objects, you can select the Modify ribbon tab, then find and select the button representing one of those Object Types, either Allignment or Parcel (they are all in the Design panel.) After selecting the object type, you see Renumber Tags near the far-left (is that an oxymoron near the far left?).
Optionally, you can just pick the object, an alignment or parcel, in the drawing area. The ribbon that appears will have the Renumber Tags button.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 9
andrewpuller3811
With regard the <Object Name> reference, i think you need to substitute in the name of the type of the object your label is attached to.
For example, if you are looking to modify an alignment label/tag, select the alignment in the drawing, and the Alignment context tab will be displayed on the ribbon, which wil have a "Label and Tables" panel with a button "Renumber Tags".
 The same should be true for featurelines, parcels and figures.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 4 of 9
AllenJessup
Andrew is correct about the <Object Name> and the contextual tabs. Just be aware that if RIBBONCONTEXTSELECT isn't set to 1 you won't see this behavior. If it's set to 0 you'll never see a contextual tab. If it's set to 2 you have to double click the object.
Allen
Allen Jessup
CAD Manager - Designer
Message 5 of 9
Sorry for the delay in response/ lack of accepting solution.  I've been preparing and ALTA, working overtime, and just needing to do what it takes to move forward.  Now I have time for my issue again.
Per tcorey - I did go to the "Modify" Tab of my ribbon and it has 'ground data' 'design' 'profile & section views' 'edit geometry' edit elevations' and 'modify' Panels (Panels, not tabs).  That didn't help, but I'm not using tags along Alignment or Parcel.  Pick the object helped, and is my work around for now, if the object is the label and not the actual object which is a line.
Per andrewpuller - this seems like a good idea.  My object is a Line.  I have no Line tab.  This could be useful if I label and object of the sorts you mention, so I look forward to trying that.
Per AllenJessup - My system variable is 1.  The mere mention of 'contextual' makes sense as I do the button I want when highlighting a tag label.
So, I have a work around but would like to try the actual instructions provided by Autodesk.  The instructions don't tell me to highlight or select the label.  What?  Here is where I'm stuck.  Help file for Renumbering Lable Tags Step 1:
1. Click <Object Name> tab -> Labels & Tables panel ->Renumber Tags.
BTW - the very closest I get to anything resembling the step 1 instruction is by clicking the "Annotate" tab, it has a "Labels & Tables" panel, but no such "Renumber Tags" to click on so it's a dead end.
FYI - with the work around, highlighting the tag label first...  a green colored tab appears on the ribbon "Labels - General Segment Label" with a "Modify" panel, with the "Renumber Tags" button.  That's pretty darn close.  It's different for sure, but pretty close.
Message 6 of 9
AllenJessup
I think the first step should be 1. Select Tag to Renumber. Click <Object Name> tab -> Labels & Tables panel ->Renumber Tags
Working from <here> I captured the following 2 pictures. See if they help make sense of the procedure.
Allen Jessup
Message 7 of 9
AllenJessup
"Labels - General Segment Label" is the <object name> in this case. The instructions may not be specific. But I believe that this is what you're being instructed to do.
Allen
Allen Jessup
Message 8 of 9
Ya know, I think you're right AllenJessup.  The instructions should be different.  Highlight first, then I get the contextual and magical <Object Name> menu.  I suppose I could customize my ribbon to have that tab there all the time.  The panel is "modify" on that tab.  Perhaps the instructions are accurate for other types of objects that are already in the ribbon, like an alignment, just not the Gereral tab for the generic line objects I was working with.  Thank you.  Resolved well enough.  Plus 1 for convoluted AutoDesk help files.  At least they try.
Message 9 of 9
AllenJessup
One of the hardest thing in trying to explain something is to forget what you already know. The instruction made sense to me because I was already used to selecting objects to get the contextual tab. So the author had already done that step in their mind when writing that. It doesn't make it right but it makes it quite understandable.
Allen
Allen Jessup
Rail Community
