Can someone tell me why it's taking so long to save a file. I can't attach the file, its too large.
That's a very loaded question without any specific information re:
The first thing I'd try is cleaning out your Windows Temp folder if you haven't done so.
C:\Users\username\AppData\Local\Temp\
Close applications & delete everything it will allow, Launch c3d & test save.
Does the 12 mb file size seem normal when compared to other similar projects?
I tried wblocking (to scrub the header) your drawing and got an error that there are proxy object and the wblock is rejected. what do you have in there that isn't native to civil3d?
Your Name
Your Name
