I have been using autocad for a while now and can't get a simple horizontal
alignment report including the coordinate of the bc,ec pi coordinates of
curves for the alignment taper. I will try to explain a little bit what I
would like. I currently have a alignment (see below) with curves. From that
alignment I have a new alignment based on a offset distance. As you can see
the new alignment is not all copy parallel distance.What I would like is
that all offset distance be in a taper on tangent and if it is on a curve I
would like a best fit curve (repeat best fit curve) no compute curve by two
know points all reference to the main alignment.
Any help would be appreciated.
Station North Easting Radius
717+30.66 1903527.8828 6251454.9240
718+82.38 bc 1903675.8828 6251787.8700
721+31.94 ec 1903918.5372 6251456.9455 361'
724+07.32 bc 1904163.7574 621331.6390
726+08.37 ec 1904356.2747 62251278.7536 492'
736+02.31 bc 1905348.1958 6251215.4053
745+46.33 ec 1906078.1079 6250695.3235 850'
746+84.14 1906161.3180 6250568.1980
Right tw. station Right tw offset transition
715+50 11'
717+50 12'
720+22 12'
725+22 24'
728+40 24'
728+75 24'
733+75 12'
742+92.826 12'
744+50 12'
746+50 11'
