first thank you very much for your help, we wonder if there is some way to make embankments as images attached to a side road and canal road will be built first, then the second plateau which will support the road because all water collected on the plateau will be directed to the canal road, I'm able to do for Granding and feature line but takes a little work, would like to know if you have a more automated way through section type, profile, alignment, subassemblies. I hope you understood.
Your Name
Your Name
exactly
but I'm not managing to do
could help
I'm sending attached file
Your Name
Your Name
I see in your file you already have assemblies set up for this. Im assuming these are 'ASSEMBLY - 03' and 'ASSEMBLY - 04'. Those should do what I believe you are asking. Create a desired profile along 'ALINHAMENTO_05' (Im assuming thats the one you want, if not, use whatever appropriate alignment) and create a Corridor from it, using that assembly you made. Then in the Corridor Properties, you can create a Corridor Surface, and that will stay dynamic to your Assembly and Profile.
