Civil 3D Forum
hello good day I'm having problems with the command copy paste to original
2 REPLIES 2
255 Views, 2 Replies
hello good day I'm having problems with the command copy paste to original coordinates move when I select it does it can be?
2 REPLIES 2
itr0045
Can you please re type your question?  It is not very clear what you are asking.  Thanks!
brian.strandberg
in reply to: itr0045
I am assuming you are using the COPYCLIP and the PASTEORIG commands.  I can think of a few things that could cause this to go wrong.
Different units in both drawings.
Different coordinate systems (type in UCS W) before executing both commands.
Different settings of ANGDIR (usually kept at 0)
Different settings of BASE (usally 0,0)
I'm sure there are many more.
Try using COPYBASE with base point 0,0 and PASTEBLOCK insertion point 0,0
I rarely have time to post. If what I post helps please use Accept as Solution / Like when appropriate.
Check out my Civil 3d blog at: http://c3dk.com/
Rail Community
