I have been unable to attach two pipes to a headwall. Tried to make the headwall wide enough but each pipe still overlapped. My current work around is to use two headwalls. Is there a way to get the double pipes with a single headwall? or am I stuck with two headwalls.
Solved by Neilw_05. Go to Solution.
Try a forum search for "double pipe". There are several similar posts on this question.
Thanks for the quick reply. Was able to find something that worked pretty well. Simple yet effective.
Steven,
It's great that you found a solution. Could you share what you found?
This solution is a drafting workaround and does not create a true BIM model object. Can users expect added pipe/structure features in the future to support double/triple/quad barrel pipes into a single structure? The solution looks odd in Navisworks too and doesn't work when importing/exporting using SSA.
how could i drow double barrel attach to head wall
