been using autocad for many years and have a great grasp of "regular" autocad. I can't seem to get comfortable with the layering in c3d. My issue: I have done some cross secitons and have a major grid and minor grid. In "regular" autocad, I could just select "layoff" from the layer tools and select, by entity, the layer I wanted to turn off. Now with the section views, I can select the layer I want turned off, and the entire thing goes off. Just curiouis on how others are handling this.
Solved by Jeff_M. Go to Solution.
Use layman or the style to change the layer visibility of the subcomponents. Yes, it took a long time to break myself of trying to use LAYFRZ or LAYOFF. The Sincpac-C3D SPLayFrz, SPLayOff, & SPLayIso commands help a lot, but don't work with all C3D objects.
