Civil 3D Forum
Hatching Option In Profile View Properties
5 REPLIES 5
901 Views, 5 Replies
I am trying to show cut and fill hatching in the profile views but the hatching doesn't show up. I've tried changing the hatching styles, the scale, the colors, etc. but it doesn't seem to be working. Does anyone have a solution to this?
5 REPLIES 5
just a couple quick checks
confirm you have profile picked when setting up the hatch, it defaults to plan view every time you access it
and confirm the layers setting are turned on in the layer manager, basic suggestions
otherwise sound like it should be working
I had check those in the beginning and it still didn't work but i figured it out about an hour ago. I had to go into the profile view display properties because the profile view style i was using had the hatch component off.
glad to hear
cheers
Ken
BrianHailey
You should mark your response to your thread as a solution so others searching for the same issue will see that there is a possible solution in this thread.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
kwilktrihydro
I'm so glad you marked this as the solution.......I have banged my head over this for a long long time.
Kelby Wilkison, P.E.
Civil Engineer
Trihydro Corporation
Rail Community
