Hello everyone, Can someone tell me why my co-worker's hatch pattern looks like a bunch of lines and triangles?
We are both using the gravel hatch and mine is fine, but his looks like what I described above. Same scale in the drawing, i'm using civil 3013 he is using 2010.
thanks
Solved by drafter1411. Go to Solution.
in the hatch ribbon you can reset the hatch origin in the area to be patterned
Your Name
Your Name
As Joe said, simply set the new origin somewhere in the hatch. Each hatch has a default origin, and the further away your hatch is from it, it can make it display funny, like what you are experiencing.
