Civil 3D Forum
Hatch Pattern Not working Propoerly
6 REPLIES 6
mikeshick
5179 Views, 6 Replies
I use Autodesk Architecture and Civil 3D.  I usually print projects sheets that contain both civil and architecture form Architecture, but occassionly print sheet sets through civil 3d.
Recently, I have had a problem with one hatch pattern available to Architecture but not civil 3d not printing properly through c3d.  I added a support file search path to my c3d to point to location of architectural hatches, but the problem did not go away.
Does anyone know how to fix this?
thanks!
Mike Shick
www.medesigns.us
6 REPLIES 6
Neilw_05
in reply to: mikeshick
Can you describe what the problem is? "not printing properly" is vague.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
mikeshick
in reply to: Neilw_05
My bad...going to fast.  The hatch pattern shows up solid.  The same file opening in Architecture has no problem.
Mike Shick
www.medesigns.us
Neilw_05
Further clarification needed. Does it appear solid in ACAD or only when you plot? Is it possible there is some kind of mask that is obscurring it?
WIN 10 64 PRO
Neilw_05
Perhaps this thread is related: http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012-DWG/hatch-turns-solid-when-dwg-opened-in-Autoca...
WIN 10 64 PRO
mikeshick
the hatch patter shows up solid in both Civil 3D and in Plotting.  But the very same drawing file opens up fine in Architecture.
Mike Shick
www.medesigns.us
mikeshick
You're awesome.  The HPMAXLINES sysvar to 10,000,000 from 1,000,000 seemed to do the trick.  Thanks, Neil!!!
Mike Shick
www.medesigns.us
Rail Community
