Civil 3D Forum
hatch pattern issue (pattern to solid)
6 REPLIES 6
nostupidquestions
686 Views, 6 Replies
i've got a hatch pattern that is the DOT pattern for existing asphalt. it's annotative because i have 2 viewports, one at 20 scale and a detail at 5 scale. for some reason it randomly turns solid in the 5 scale viewport. am i missing something about annotative hatch patterns?
Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz 3.91 GHz
64 GB RAM
C3D 2023.2
6 REPLIES 6
Jay_B
in reply to: nostupidquestions
Are "Annoallvisible" and "Annoautoscale" both turned on on lower right of screen?
Is it actually being switched to Solid hatch pattern or is it a scale density issue?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
nostupidquestions
in reply to: Jay_B
it still says it a dot pattern, just showing up solid. this morning it was working fine. both of those toggles are on.
64 GB RAM
C3D 2023.2
there are actually two 5 scale viewports. one is dots and the other is solid. frustrating.
64 GB RAM
C3D 2023.2
Would you mind sharing your drawing so we could have a look at the issue
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Jay_B
Hmm, Try using the "Match Properties" command. Select the edge of the good 5 scale VP then the Bad one.
C3D 2018.1
C3D 2016 SP4
nostupidquestions
in reply to: Jay_B
it's working correctly now. don't know what i did. thanks though.
64 GB RAM
C3D 2023.2
Rail Community
