i've got a hatch pattern that is the DOT pattern for existing asphalt. it's annotative because i have 2 viewports, one at 20 scale and a detail at 5 scale. for some reason it randomly turns solid in the 5 scale viewport. am i missing something about annotative hatch patterns?
Are "Annoallvisible" and "Annoautoscale" both turned on on lower right of screen?
Is it actually being switched to Solid hatch pattern or is it a scale density issue?
it still says it a dot pattern, just showing up solid. this morning it was working fine. both of those toggles are on.
there are actually two 5 scale viewports. one is dots and the other is solid. frustrating.
Would you mind sharing your drawing so we could have a look at the issue
Hmm, Try using the "Match Properties" command. Select the edge of the good 5 scale VP then the Bad one.
it's working correctly now. don't know what i did. thanks though.
