Let me start by saying I am not a user of AutoCAD Civil 3D 2013 but am part of my county's IT department and I am trying to troubleshoot a user's slow performance when using Hatch. Please keep in mind I'm not familiar with the interface or the terminology so do not know what to ask the user or what settings to check.
The computer is a Dell Precision T3600:
32GB of RAM
Nvidia Quadro K5000 4GB
Windows 7 Professional 64bit
1TB 7200rpm hard drive.
The file he is working with is only about 5MB and according to him has been working on it for a few weeks with no issues until a few days ago when Hatching became extremely slow. When he would first start AutoCAD the first Hatch would usually complete in a few seconds and then any following could take anywhere from a minute to 5 minutes or he would shut down AutoCAD and try again. Per his usage he says this process used to be instantaneous, not even taking a few seconds.
I've had him do the following with no success:
1)turned off HPQUICKREVIEW
2)Ran an AUDIT (found 0 errors)
3)set FIELDEVAL to 4
I also did a Repair from Windows programs with no effect on performance.
I had asked him if he had any unnecessary layers and he said the file was already flattened. I had him zoom in further before trying Hatch and this 'seemed' to be quicker. Is this an indication he didn't actually perform some of the suggestions I provided? From my research, the Hatch command will process all the visible data when using as 'point'. I tried to get him to set boundaries but he only responded he never had to do that before. What could possibly be different about this file?
What other options can I try? What other data should I gather? What other questions should I ask the user about his project?
I will be dealing with AutoCAD on a regular basis in my organization(not as a user though) for the foreseeable future so I would like to know how to properly gather data and how to approach troubleshooting performance issues.
I've attached the .dwg file if anyone wants to take a look but per the user, Hatching worked just fine on a co-workers machine using the same file.
I'll take a look at the file but WBLOCKing to a new dwg file or INSERTing to a new dwg may help
EDIT: Just had a look at the file and was able to change hatch patterns, angle and scale and performance was as I expected......
Thanks for taking a look. This is what I'm experiencing with my user. He is the only one having issues with Hatch. I gave him the AutoCAD Service Pack 2 to install. If that doesn't help, should I just reinstall? If so, any tips when uninstalling/reinstalling?
I opened the file noted it was at a high coordinate value (i.e. state plane) change the Hatch orign of the concrete hatch and I can hatch a rectangle in about 2 seconds.
Hatch patterns don't like high coordinates, when you hatch at high values try setting a defualt orgin for the area in questions. This will also make the conrete hatch pattern plot correctly.
i5
6gb ram
C3D13
Rick Jackson
Survey CAD Technician VI
Thank you for the suggestion. I passed this onto my user and he said that was essentially the same as making a boundary, something he did not have to do before and something I tried to get him to do previously. Setting a default origin sounded like a different approach to me.
This is what I'm dealing with where it is like pulling teeth to get a user to try something. I definitely appreciate the help though.
I will keep pushing my user to use boundaries. There is no guarantee a reinstall will solve his problem so he can either learn to workaround these type of occurrences or continue to suffer degraded performance.
On a side note, is there any type of logging I can turn on that can help me find the root cause why his install of AutoCAD does not perform as well as others with the same file?
