Civil 3D Forum
Hatch Creation Ribbon Contextual Tab Causes C3D 2013 to hang
4 REPLIES 4
ShawnMcCorkle1211
524 Views, 4 Replies
When I try to access a hatch pattern from the Hatch Creation Ribbon Contextual Tab, C3D stops working and I have to force the program to quit.  I've tried repairing the installation, which didn't work.  I've also compeltely uninstalled and then reinstllaed the program, and have applied the Service Pack 1 update, but the problem persists.
However, accessing a hatch pattern after using the "Hatch" command from the command does seem to work.
4 REPLIES 4
do you have any custom hatch patterns added (*.PAT)?
If you start Civil3D with profile "as AutoCAD", do you have the same problem?
At least I have tried it (with German release of Civil3D SP1) and don't have that issue.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
I have no customized patterns.
I also have the same issue when running "As AutoCAD 2013".
if you look to the taskmanager: does AutoCAD (or any other process) need a high kernel-load? Or is the processor at a load of about 0%.
Another option to try: login to your system with another Windows-user-account/with admin permission/with disabled antivirus .... what happens then when you try to reproduce that issue?
- alfred -
Alfred NESWADBA
Ok.  I think I figured it out.  One of the patterns had been corrupted.  Once i removed it, it seems to work ok.
Rail Community
