anne27 wrote:
> Thank you for the suggestion CJ based on the suggestions I am considering another model
> Here are the specs
> Intel Pentium 4 650 - 3.4GHz 64-Bit Processor,
> 2 GB DDR2 533MHz ECC SDRAM,
> 160GT SATA-300 Hard Drive,
> NVidia Quadro FX540 - 128MB PCIE - is this good enough?
> Most the data is stored and will be accessed from the server I checked with our HP vendor and he thinks this is good enough. Have you faced any challenges with running LandDesk 2006 on 64bit machines?
> Thanks
> Sabina
I should clarify that I am still running WinXP Professional 32-bit. The
AMD platforms (ones that use Athlon 64/FX/X2) are compatible with 32-bit
and 64-bit OS's and applications. I am not very familiar with how the
Pentium CPU's are spec'd, but if that system comes with XP Pro 32-bit,
then it is a similar situation. Based on other forums that I have read,
I would stay away from 64-bit XP due to lack of hardware support
(drivers), although I have no experience with the OS myself.
Other than that, the system is appears fine. The FX540 only has one DVI
output (if that matters). I would get a quote on a similar machine but
based on the AMD platform (Athlon 64 or 64X2). In my opinion, it is a
better platform.
I have the benefit of building our workstations, so I can pick each
component.
You may get more informative responses by posting in the hardware
discussion group.
