Hi-
I've noticed that when I use the intersection wizard and I have an assembly for a half section of the road that includes a sidewalk, the sidewalk is often not included in the corridor.
I've attached an image. This particular intersection has two regions: one with parking and one without.
Any help would be greatly appreciated!
Thanks so much!
Meredith
C3D 2014
Windows 7 64-bit
Solved by mermerCAD. Go to Solution.
Thanks for the suggestion, but the assembly assigned to the region definitely has a sidewalk subassembly.
I think I figured out how to fix it. We put all of our roads into one corridor file. When an intersection is created, it creates a new baseline along the primary road. I removed this baseline and added the regions to the main baseline for the primary road and the sidewalks showed up! I don't know why it worked, but it did.
Thanks again for your help!
Meredith
Thank you for your post! After an afternoon of trying to figure out the problem, this solution fixed it.
