Hi Chad,
The purpose of the Guardrail subassembly is to show the Guardrail detail on
sections sampled for the corridor. There is no extrusion to the
corresponding points of the guardrail between the adjacent sections (as the
out of the box functionality).
If you want to experiment, coding of some links on the guardrail would need
to be declared as TOP surface. Be aware though that overhangs don't mix
together with surface objects...
regs
Rad
"Chad Wurzer" wrote in message
news:422e173f$1_3@newsprd01...
> I looked into this a little more and I opened the basic guardrail in the
VBA
> Editor. I do not know much about VBA yet (OJT), but I see that there are
> variables for post width, rail width, and rail height. The question is,
> what value do I need to add to the VBA string to get these variables to
pop
> up when I select the basic guardrail.
> Right now it is only popping in at a profile view of the guardrail, but it
> looks like it has the ability to be a solid - what do I need to get it to
> that next step??
> I am not looking for a VBA lesson, I realize there are a lot of help
topics
> on this, but I could really use this guardrail as a solid post with the
rail
> attached. Could someone please tell me how to do this, or if it is even
> possible. Seems odd to me that the settings are in the VBA command for
> basic guardrail, but are not being used??
> Thanks,
> Chad
