Civil 3D Forum
Guardrail in Subassemblies
4 REPLIES 4
410 Views, 4 Replies
Is there a way to edit the geometry of the guardrail in the daylight
subassemblies? The one provided does not meet TDOT standards and I
would like to be able to use the built-in one instead of making a block
and placing it manually in each cross section.
EB42
Civil 3D 2008 SP1
Quad Core Xeon
(3)250GB SATA Drives
2GB RAM
4 REPLIES 4
Civil3DReminders_com
I think you will have to go into the VBA file that ships with the product and make any changes you want there. The location of the file is: C:\Documents and Settings\All Users\Application Data\Autodesk\C3D 2008\enu\C3DStockSubassemblyScripts.dvb
I've been told help has a good description on how to modify/create the subassemblies, I just haven't looked at it yet.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
All the subassemblies that are inserted in 2008 are .NET. The VBA subs were
only provided for backward compatability (AFAIK) so the Guardrail sub would
need to be modified in VB.NET and a new DLL built & copied into that folder.
wrote in message news:5719033@discussion.autodesk.com...
saluki
jeff, can you use vb.net express edition to make the changes and compile the dll?
Yes
wrote in message news:5719201@discussion.autodesk.com...
dll?
Rail Community
