ken
Active Member
ken
Message 1 of 10 (2,064 Views)
Group Dialog box missing
2064 Views, 9 Replies
06-05-2011 03:29 PM
Hello, I am running 2012 and my group dialog box is nowhere to be found. (I opened 2011 and the dialog box pops up)
I just get a command prompt to select objects or [Name/Description]:  -group gets me command line as usual. I enter a lot of legal descriptions and set them as various named groups for boundary analysis. Selecting the various groups via dialog is much easier. I have checked system variables but I cannot find anything I need to change. I have searched the discussion groups also but could not find any info. Any help would be appreciated.
Ken Robbins
Civil 3D 2012
Win 7 64
i7-980x
24gb
quadro fx 1800
XEON E3-1270
32 GB RAM
Win 7 Pro 64
Civil 3D 2013
256 GB SSD
2TB HDD
nVidia Quadro NVS450
3 monitors
(all available hotfixes/updates applied)
Hi Ken,
The group command is now in 2D Drafting and Annotation workspace. If you want to see the dialog you would need to run CLASSICGROUP command. Not sure about changes, though.
See also: http://heidihewett.blogs.com/my_weblog/2011/05/object-groups-in-autocad-2012.html
Product Support
AlmasSuljevic
Message 2 of 10 (2,043 Views)
Re: Group Dialog box missing
06-06-2011 11:16 AM in reply to: ken
Hi Ken,
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
rkmcswain
Message 3 of 10 (2,042 Views)
06-06-2011 11:38 AM in reply to: ken
ken
Active Member
ken
Message 4 of 10 (2,033 Views)
06-06-2011 01:06 PM in reply to: AlmasSuljevic
Thank you. I knew it was going to be something simple.
XEON E3-1270
32 GB RAM
Win 7 Pro 64
Civil 3D 2013
256 GB SSD
2TB HDD
3 monitors
Distinguished Contributor
d_reno
Message 5 of 10 (1,850 Views)
01-17-2012 10:02 AM in reply to: ken
I found this article before I came to the group. The Civil 3D Home tab does not have a Group panel. Not sure how to set this up - took one stab using CUI and partial (AutoCRUD) menus, but no luck. I hate not conforming to the new updates, but at this point CLASSICGROUP will be just as easy after I redifine the "g" alias.
David Renaud, RLS
C3D 2012 on 64bit Win 7 all up to date
Dell Precision 7core 8GB RAM
NVIDIA Quadro FX 1800M
LDT/C3D user since release 12
d_reno
Message 6 of 10 (1,845 Views)
01-17-2012 10:09 AM in reply to: AlmasSuljevic
CLASSICGROUP is not woking quite right.
I am using this because it is a hassle to switch workspaces and have my toolbars fly all over.
using CLASSICGROUP the group does not behave as is it were selectable, no matter what is set in the CLASSICGROUP dialog.
I am think that since I first invoked the command using GROUP, selected some object but with NO dialog or other way to control what was going on, it is stuck on some undesirable setting.
This is something that wasn't broke, so shouldn't have been "fixed."
David Renaud, RLS
d_reno
Message 7 of 10 (1,842 Views)
01-17-2012 10:15 AM in reply to: d_reno
switched workspace to 2D Drafting and found the Group Selection switch. I'm sure this was meant to make us all oh-so-efficient as drafters, but I am not seeing it at the moment,
David Renaud, RLS
d_reno
Message 8 of 10 (1,722 Views)
04-17-2012 06:34 AM in reply to: d_reno
Can anyone describe how I can get the Group Entry on the 2d Drafting & Annotation workspace Home ribbon to my Civil3d workspace Home ribbon? Or, does anyone know how to switch group selectability on/off without having to use the above mention 2D ribbon?
I dislike switching workspaces since my toolbars fly all over and have to be dragged back to where I want them everytime I switch a workspace.
thanks.
signed, nimrod
David Renaud, RLS
Jeff_M
Message 9 of 10 (1,718 Views)
04-17-2012 06:56 AM in reply to: d_reno
Group Selection
To edit the C3D Ribbon:
CUI
in the Customizations in all files panel expand Partial Customization Files, then expand Acad, then Ribbon, then Panels. Scroll down to Home-Groups (mine is 7th from the last in this branch), right click, copy. Scroll back up to the main CIVIL branch, expand Ribbon, then Tabs, right click Civil 3D Home, paste. Hit the OK button.
d_reno
Message 10 of 10 (1,709 Views)
04-17-2012 08:57 AM in reply to: Jeff_M
Thanks, Jeff, that did it. I was in the cutomization of the Civil3D workspace when I didn't need to be.
David Renaud, RLS
