Vic wrote:
> Not true. I've used nothing but 2009 on this project and I see the
> ground line shifting every time I open the drawing. I have all service
> packs for C3D 09 installed, Help > About says "version 4"
> I have SP1 for 2010 installed, still have the issue. I'm not the only
> one in our company that has the problem.
To be clear:
>> This issue did not affect C3D 2009, so it should not happen in that
>> version.
When I said that, "this issue" referred to the issue fixed with Update 1
of C3D 2010. If you are experiencing an issue in C3D 2009, that may not
be the same problem. I'm not disputing the fact that you may be
experiencing the problem that you describe.
As far as the issue occurring in 2010, I am still not sure whether you
migrated the drawing from 2009. If you did, you must reopen the
original drawing in 2010 *after* the update has been applied to see the
issue resolved.
Himanshu Gohel. Civil 3D Team, Autodesk, Inc.
Autodesk Civil 3D Product Information: http://www.autodesk.com/civil3d
Civil Engineering Community Portal: http://civilcommunity.autodesk.com
