My road corridor regions can't be stretched using the region grips when 'geometry locking' is on, grip stretch works when i change the locking option to 'station locking', but it used to work fine also with geometry locking on.. It has happened somehow to all my files, so it seems to be caused by some application setting, the corridor regions can be stretched from grips fine on other pc's. (C3d 2013)
Hi robert06,
I tried to get that behavior and it all works OK on my end with both options. I'd suggest that you see if you get the same issue with different login. Is your program up to date?
Can you post a drawing which isn't working on your system, so that others can test it?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
This is currently the case with all my civil drawings, it just turned to be like this in a while. I have tested my files on other pc's and there is no such problem with the corridors. Program is up to date.
When trying to drag a region grip, the corridor gets unselected.
Was this problem ever solved? I have found myself in the same situation in all drawings.
