What is the gray area on the clipped out portion of the plan sheet in the attached pic? Can it be adjusted so that when a station number falls directly on the clip it is not cut in half? I have been placing a number in paper space right on top of the referenced number and I am looking for a better solution.
Solved by Jeff_M. Go to Solution.
C3D Labels still leave some things to be desired... This is one of them. The ability to automatically hide "chopped off" C3D labels in a paperspace viewport would currently fall into the category of a "wish list" item.
I label the alignment stations in the Plan sheet. This way I can make sure the draw order is above the Xref of the base sheet. In one City I work in, they prefer the station to be shown for the match line, so using this same method I can turn off the display of one station label by shift+selecting it.
