Active Contributor
1 Kudo
Post 1 of 7
Gravel Hatch
417 Views, 6 Replies
01-16-2013 09:59 AM
 I am drawing an area of cobblestone. I am using the gravel hatch pattern and scaling it up. Is there a way to have the hatch pattern close the circles of the gravel peices at the boundary? Or is there another hatch pattern that can do this?
169 Kudos
Post 2 of 7
Re: Gravel Hatch
01-16-2013 11:16 AM in reply to: jpc5520
Usually this is due to being too far away from the origin point.  If you move you model closer to 0,0 and then hatch it, it should look better.  Then you can move your model back to original place is you choose to.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
263 Kudos
Post 3 of 7
Re: Gravel Hatch
01-16-2013 11:51 AM in reply to: TRogers
You don't have to move.  You can just set a hatch origin in the hatch edit dialog or ribbon area.
Credit where credit is due! Give kudos or accept as solution whenever you can.
343 Kudos
Post 4 of 7
Re: Gravel Hatch
01-16-2013 11:55 AM in reply to: troma
changing the hatch origin is definitely the way to go
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Active Contributor
1 Kudo
Post 5 of 7
Re: Gravel Hatch
01-16-2013 01:49 PM in reply to: jpc5520
Thank you for the origin tip.
But, I what I am looking for is at the border/boundary of the hatch area, I would like full "circles" representing the gravel/cobblestone. Now, the gravel/cobblestone look as if a knife cut away the area beyond the boundary. I would like to have the hatch patern look as if someone layed the stones down in a square.
Valued Contributor
6 Kudos
Post 6 of 7
Re: Gravel Hatch
01-16-2013 02:26 PM in reply to: jpc5520
I don't think that would be possible with a hatch. You might have to draw a single stone at the proper size and then use the array command to get what you're after.
Mark Castle
Civil 3D 2014, SP1
Win 8.1 64-Bit, 8 GB RAM
Core 2 Duo 6400, Quadro FX 580
326 Kudos
Post 7 of 7
Re: Gravel Hatch
01-16-2013 04:25 PM in reply to: jpc5520
The best I can come up with is: over hatch and polyline clip the patter to show the whole cobble?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
