Does anyone have an imperial graphic scale dynamic block that they wouldn't mind sharing? I have scoured the internet for one without luck.
Thanks!
Solved by BrianHailey. Go to Solution.
Solved by gunnarl. Go to Solution.
Thank you for posting those instructions, I learned from them. I was using the block in C3D 2011 but it was too small to read in paperspace, something was off.
Brian,
I enjoyed your movie clips. 🙂
I have been doing the second method for a while now but the scale bars provided are not what I need. So I have been trying to follow the instructions in Civil 3D 2018 to try and create my own dynamic blocks.
I have had limited success, and maybe you, or another knowledgeable person, can get me working.
I was able to get the Horizontal and Vertical scale labels into my symbol (clip attached), and they update correctly with a viewport scale change. However, the scale bar will not scale up/down and the units labeled on the scale bar are simple text so they do not update. I have followed the steps outline in the help file and tried to get the "Map.ScaleBar.Division.Label" variables to work without luck. I could also not get the Action Parameters to scale the symbol based upon the viewport scale.
Does anyone have a "step-by-step" fool proof tutorial to create a dynamic scalebar that works!
An example of what I need is attached.
I am getting very frustrated and hope someone can help!
