I have Radeon HD 3850 256MB, 256bit graphic card on my computer and I intend to replace it, but I am low in buget. So, I want to know whether the Radeon HD 6850 is a good choice for common use in Civil 3D, or I need to get some Nvidia card or Quadro card to improve work experiance in Civil. Thank you in advance for your reply.
Have you checked the recommended hardware list?
Based on past experience I tend to prefer nVidia cards. A good gaming card should be sufficient, but a Quadro can be better for point cloud work (if you will be using ReCap, it has some specific hardware requirements that must be met). Don't expect throwing money at a problem will make it go away. More than most programs, Civil3D is very dependant on proper work procedures and data management.
A very true statement...
I don't use point cloud, my drawings mostly have 2.000-3.000 points ( roads about 4-5 km lenght). I have problem when I want to view surface or corridor in 3d orbit, somethimes even when zooming in 2D view, Civil simply not responding. Also, it is wery slow when creating corridor. I have to say that I am new in Civil 3D and that slow responding of program discourages me to continue with learning. I found one Quadro FX 3700 with good price and I wonder if it would improve performance and remove problems that I have, or buyng a HD 6850 or similar card (either ATI or NVidia) will be better solution? I am interested in what specifications of graphic card are most important for work in Civil (amount of RAM, RAM speed and bit dept, or GPU speed or something else). Sorry for my bad english, I hope that I succeeded to explain to you my problem.
I also agree. Here's a link to the Hardware List.
Allen
Allen Jessup
CAD Manager - Designer
3DORBIT in AutoCAD and verticals have always been a bit dodgy for anything other than very simple/low-polygon models. The program was never really intended to be real-time visualation software, so even with a high-end graphics card you won't be seeing the performance you might expect. It won't compete with dedicated software like Navisworks (which is what our designers use to look at the models) or Inventor which are designed from the ground-up to operate in a shaded 3D mode. I'll have to leave the detailed diagnostics of corridors to those more knowledgeable than myself.
It can be discouraging, but its best to compare apples to apples. Its not really fair to compare it to most software we deal with on a day to day basis, where its click-click-done. The difference in the calculations and data manipulation done by Civil3D is orders beyond those programs.
Question I asked here was related to the graphics card, but from your responses I can get a conclusion that I need a lot more to learn about working in Civil 3D . In any case, I hope to here will be able to ask for help for every problem that I encountered in the future. Thank you all for answers!
