I would like to disable dinamic behavior of grading, because some times I only want to find the polyline or featureline that intersect the surface, but with dynamic behavior of grading it takes a long time. Is it possible?. Something like Site Design of Eagle Point software.
I'm sorry, but my english is not good 😃
Thanks.
Solved by Jeff_M. Go to Solution.
You can't. Best you can do is explode the grading, leaving the feature line behind.
Yes, you're right. I can explode the grading, but the problem is that C3D take a long time to draw the grading. I'm looking for the best place to built a dam for tailings storage facility and i need to make a lot of gradings in a big surface, that's why i wanted to new if C3D can do this very quickly.
Thank you for your answer,
Best regards from Perú.
Have you considered using corridors for your dams - a lot less buggy than grading objects??
There is a useful class on AU online from 2011 (CI1861 That Dam Corridor: AutoCAD® Civil 3D® Modeling for New and Rehab Dam Projects) that deals with this very application
neilyj (No connection with Autodesk other than using the products in the real world)
