To use the infill, you will need to create a closed figure.
wrote in message news:4997969@discussion.autodesk.com...
One more question, if my berm is a joined line (closed square) and I go to
make an ifill then the volume is good infill works. If I have 2 separate
lines as my berm crest and I project each line to either side then the
infill will not work.
How do I create the infill if there are 2 separate lines can this be done?
Thanks in advance.
Canon
