AutoCAD Civil 3D General Discussion
*Brian Hailey
Post 1 of 4
Grading Tutorial Crashes
69 Views, 3 Replies
02-17-2004 08:51 AM
Hello all, While going through the tutorials, I cannot edit the feature line in the drawing grading-3.dwg. Here is what I am doing: First I open the drawing, then, in the grading menu, I select Elevation Editor..., then, in the elevation editor, I try to change the elevation at station 0+00.00 from 650' to 645'. This is when it crashes and I get the error message (see attached image). Any ideas? I have Windows XP Pro, P4, 2.4 GHz, 512 MB of Ram, Radeon 7500 video card, and Civil3D has service pack 1 installed. Thanks in advance, Brian
*Darron Agawa
Post 2 of 4
Re: Grading Tutorial Crashes
02-17-2004 09:27 AM in reply to: *Brian Hailey
Brian, I've had the same thing happen to me. My understanding is that Grading is still not ready for much use. I just decided to give up on Grading until it matures a little more. Good to see you're still at it! -- Darron K. Agawa Civil Engineer Town of Windsor
*Brian Hailey
Post 3 of 4
02-17-2004 09:52 AM in reply to: *Brian Hailey
Thanks Darron. I definitely think Civil3D has a lot of potential but still isn't quite there yet. Brian "Darron Agawa" wrote in message news:40324f0f$1_2@newsprd01... > Brian, > > I've had the same thing happen to me. My understanding is that Grading is > still not ready for much use. I just decided to give up on Grading until it > matures a little more. > > Good to see you're still at it! > -- > Darron K. Agawa > Civil Engineer > Town of Windsor > >
*Glen Albert
Post 4 of 4
02-17-2004 11:15 AM in reply to: *Brian Hailey
Brian, I was able to reproduce it so I've submitted a defect. It's a problem in the recalculation of the grading for the change in elevation. Thanks, Glen "Brian Hailey" wrote in message news:4032467e_2@newsprd01... > Hello all, > > While going through the tutorials, I cannot edit the feature line in the > drawing grading-3.dwg. Here is what I am doing: First I open the drawing, > then, in the grading menu, I select Elevation Editor..., then, in the > elevation editor, I try to change the elevation at station 0+00.00 from 650' > to 645'. This is when it crashes and I get the error message (see attached > image). Any ideas? I have Windows XP Pro, P4, 2.4 GHz, 512 MB of Ram, > Radeon 7500 video card, and Civil3D has service pack 1 installed. > > Thanks in advance, > > Brian > > >
Post to the Community
New Post
