"KentYoungberg" wrote in message
news:15184905.1098379377685.JavaMail.jive@jiveforum1.autodesk.com...
> I am using an example from the K-TEK Autodesk Civil 3D book from the
Working with Grading Styles section, page 404. In step 10, I select the
Grading Properties button, and am prompted to
> "Select a Point in the Grading or [Edge]:"
> I then select in the grading group object in the display area, and the
prompt returns to
> Command:
> I am expecting the Grading Properties dialog box to display.
I don't have the book with and I'm not sure which part of the object you are
selecting, so what I can suggest is to select a different edge. With your
file, when I clicked on the outside edge I did not get the properties, but
when I clicked on the next inner edge, I did get the properties.
Himanshu
