I have been creating grading objects from my curb lines, assigning grades using the editor, then offsetting that line for the BACK of curb, and using the raise-lower command to raise the curb line height. If I edit the original face of curb line (gutter grade) then I go back and redo the process. Is there any way to intelligently link these two lines so that if one gets edited C3D knows the other is 0.5 feet higher (or lower) than its neighbor?
Prolly a stupid question.
chaz_
Solved by sjg. Go to Solution.
Gradings would be a great tool for modeling curbs and sidewalks, but they have proven to be unreliable (easily get corrupted and crash C3D) and they can't create mitered corners which is needed for many curb and sidewalk scenarios. Most avoid using gradings. Some resort to corridors but they also have issues when used in grading scenarios. So really there is no ideal solution at this time.
If you decide to use gradings or corridors, let us know your experience.
So far so good with grading on my end, I use lots of sites to prevent intermingling, and clean feature lines. I know its a slippery slope but they are working so far.
How do you handle mitered corners Joe?
Gradings tend to corrupt or cause crashes when they interact with each other. Putting them on separate sites should help. I would think it makes for a bit of a headache to keep everything sorted to the proper site though.
If you have two roughly parallel feature lines and grade to the left along one and to the right along the other to form a V, then if the lines are in the same site the gradings will tidy up the intersection of the two slopes but if in different sites then you just end up with two gradings.
When gradings work they are great but when they go wrong (not as frequently in 2012 admittedly) better hope you have a backup drawing.........
neilyj (No connection with Autodesk other than using the products in the real world)
I've had pretty good luck using grading objects to create curbs, gutters and pans in some pretty multi-family sites (apartments). Using corridors would be crazy and the grading objects are the easiest way. There are just some things you have to be careful of, like them touching grading objects attached to other feature lines. I have one I'm working on right now that has at least 400 grading objects and I just keep things clean and really don't have issues. I do keep voided copies every few days and I do have meltdowns on occasions as well but since I started using C3D that has been pretty normal.
I would be nervous as well. I have tested gradings in every version. I have had them disapear in every version. In 2014 the first test disappeared one week after creation. More than likely due to Audit or Recover IMO but those commands are unavoidable...
If can can offer the OP one other option with Feature lines. There is a command called Adjacent Elevations by Reference where you can select one feature line (bottom of curb) and tell C3D to raise/lower the other feature line (top of curb) by an elev difference, slope or grade. It is extremely useful to me with Fline models.
John Mayo
Just realized someone had written about file size. I just opened the file and it was 10,780 KB. Big for autocad to deal with I guess. I really don't have any big problems with it. Sometimes it crashes but after 20 years of using Autodesk products I save every few minutes so generally I don't lose much if a file crashes. I did have a grading object that I could not erase to save my life earlier today, I ended up wblocking it out...
